[RESOLVED] Timing belt?
purpeclipse
Dec 14, 2008
Tacoma, Washington
I just quit hondas and getting into dsm so pretty new at this. I just bought a 97 eclipse gts and it have around 115k miles on it. I'm thinking about changing the timing belt but not sure if I need to change anything else. My plan is to change the timing belt and alternator belt also, but some I've been looking around and seeing people also change the tentioner. My question is: What should I change along with timing belt? (is it a must to change the tentioner?)
Provided it was done on schedule, it's almost time to change it again. Timing belt, timing tensioner, balance shaft belt, unless you do a balance shaft delete. All drive belts. Check your hoses as well.
Water pump, oil pump, head gasket, throw some ARP's on that bizzatch. Intake gasket, exhaust gaskets, all belts
If its possible, eliminate the balance shafts, but its pain to do with the motor in the car still
If not, either way replace that balance shaft belt. If it takes a dump on you, you can kiss your valves goodbye practically!
Can't think of anything else, but use OEM belts!!
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
