[RESOLVED] Tie rod?
EclipsexGsx
86
Nov 21, 2008
springfield, Massachusetts
Ok so heres the problem. i took a deep right turn to get into a parking and then i heard a thumpp. next thing you know, the right side wheel is not moving with my steering wheel. So is it the tie rod because someone told me it was. Thanks
Most likely, don't be cheap and replace just the broken side. Do both sides, I would also check the upper/lower ball joints, wheel hubs for problems. If your tie rod end was wore enough that it broke, more than likely the rest of the front end needs attention.
turned out to be the inner tie rod. it snapped at the joint. good thing it didnt happened to me while driving on the highway. well got it fixed. Thanks for the help guys =]
