ECMlink [Resolved] Stock 1g ECMLink file request.
4g63t
1,568
13
Aug 14, 2005
North Iowa, Iowa
I need a stock 1g ECMLink bin file to upload on a stock DSM. I just want to able to upload a stock chip when I swap my ECU in to my other DSM to daily drive ### I'm short on cash to buy anther ECU.Thanks guys
Solution
And for sliders, you should be able to figure that one out :p
As mentioned, you can reset direct access settings to stock values automatically. The ECU config values, however, can change from release to release, so "stock" is less clear in this area. To help with that, we provide a set of "stock" ECU config files on this page:
v3configs [ECMTuning - wiki]
Just scroll down to the "Stock V3 ECU Config data files" section.
Thomas Dorris
ECMTuning, Inc.
Or are you just looking for a file with the stock settings for a 1g so you can revert your chip back to 'stock'?
Bingo! just need a settings and direct access file so I can change chip back to factory
The chip ecm tune that is currently on the chip is for another car of mine that I will not be driving. I can't change it back because I'm not sure what has all been changed on the chip because I did not tune it.
Thanks
Thomas Dorris
ECMTuning, Inc.
Solution
