turboAWDfanatic
- 347
- 36
- Aug 22, 2005
Colorado Springs,
Colorado
I have the serial to USB adapter from the Zeitronix website. It works perfectly with the Zt-2 software, but when I try to log w/ the TMO logger so I can see knock it doesn't work. The TMO software connects successfully, but doesn't see any data. Do I need to change any speed settings on the adapter? Or do I need to try a different adapter? I've searched and I know the 'Link guys have a lot of luck with the keyspan adapter, but I'd like to stick with the sewell if I can.
Any input would be great. Thanks.
The problem is that the Zeitronix has a much higher data rate, so the excel ends up using WAY more cells than the TMO export for the same amount of time.
