[RESOLVED] radiator problem
dcshoeco1041
163
Jul 19, 2008
east greenwich, Rhode Island
ok, so my radiator is leaking. it was old so i got a new one. I'm trying to drain all the anti freeze out but no matter how much it drains, the coolant reservoir stays full???
I used radiator stop leak in it, could that be the problem? i have no idea why the coolant in the reservoir isn't draining.
The coolant reservoir will not drain when you drain the radiator. You have to drain it separately. Just pull it out and dump it.
Just undo the clamp at the filler tube and pull the hose off. The the resevoir pulls right off the bracket that it is slid on.
MB
