snowborder714
Moderator
- 16,188
- 465
- Oct 15, 2006
Mechanicsburg,
Pennsylvania
1. Has anybody had any experience with this Prestone flush kit? Is it good to use? Also, which hose would I attach this kit up to?
2. Also, this site mentions using vinegar to flush out the radiator. Has anybody tried that before?
http://www.mkiv.com/techarticles/coolant_flush/index.html
Optional 2nd Flush (Vinegar Douche)
This step is optional, but some MKIV members report good success with it.
Remove the garden hose from the flushing tee, and cap the tee off.
Close the radiator drain ####.
Add a gallon of normal kitchen vinegar to the radiator, and fill the system up with water from the garden hose. Leave the radiator cap off.
Start the engine and allow the system to circulate this flush mix, topping up from the open radiator if the level drops.
Leave the heater on, and the cardboard in place from the previous steps to help the engine warm up faster - but do not allow it to run long enough to overheat with the open radiator cap.
Turn the engine off, after it has warmed up, and let the system cool down before you work on it.
Open the radiator drain and allow the vinegar solution to drain into your storm drains.
Fit the garden hose to the flushing adaptor and repeat the clear water flush you did earlier.
3. Would Prestone Super Flush be better than vinegar or a good step in addition to the vinegar?
4. I have searched the forums and some people recommend 1 bottle of Redline water wetter and some recommend 2. Which of these would be better?
I should mention that I just bought my car about six months ago, the chassis has 115,000 miles, and the engine has 10,000 miles in case that matters. I have no idea what maintenance previous owners have done to the car, except for the engine rebuild.
Thanks for the help!
