[RESOLVED] civic radiator
Status
Not open for further replies.
90rslaser
266
Apr 1, 2008
cheyenne, Wyoming
so im getting an aluminum radiator out of a civic, and putting it in my 90 tsi. but i am running into one problem everytime i run it through my head. i will have TWO freakin radiator caps. im sure thats not good, or can #### with things. so what would i do about one of the caps? how to eliminate it. if anyone has any ideas and/or pics i would appreciate it. thanks guys.
yeah i have thought about that, but i wasnt sure if it would #### with anything like pressure, temp, or any kind of cooling problem. especially if we just cut out the neck on the radiator and welded it flat.
Take a visit to the junkyard. Find a Hyundai elantra and take the thermostat housing. Hyundai's have the rad cap on the radiator.
I used one as well on my drag car but just letting you know the in/outlets on a civic rad is 1.25" as with a DSM its 1.5". That means the DSM rad hoses are to big for the civic rad but its a easy fix as you just need to cut of the neck on the civic rad, grind a bit around the hole and then weld 1.5" tubing on it. Also get a hyundai or colt thermostat housing as it does not have a rad cap on it and use the rad cap on the civic rad. Also dont forget to run a 12" thin fan.
Good luck
Status
