oldman
DSM Wiseman
- 9,788
- 196
- Jun 21, 2003
Dayton,
New Jersey
Then the FTS isn't doing its job, your fuel pressure should be at about 37psi - 10psi (-20inHg) = 27psi, where is the vacuum line to the FTS coming from?RiceKiller_TSi said:Vacuum is near 18-22 at idle (right before it cuts off) fuel pressure is at 37psi when the car is running and it raises like a champ when boost is seen.
How much pressure and for how long did the intake tract hold? Idle rpm? 18-22 inHg is a big variation, do you have idle surge? Have you check your logger to make sure TPS is set correctly and ISC is functioning properly?At first I thought it was just a boost leak so I tested then I disconnected the fuel pressure solenoid to eliminate a possible boost/vac leak there as well.
Car wouldn't start unless I kept my foot on the gas for a few seconds, and then it was dumping fuel pretty much the whole time after that. On the highway I could see the fuel gauge moving if I boosted at all. Finally, my car sputtered and lost all power compliments of the fouled plugs, so I pulled over. At that point it seemed to be idling on 2 cylinders, really roughly. After fumbling around under the hood for a few seconds I noticed my stock MAS wasn't plugged in. After making the connection, everything went back to normal.
