[RESOLVED] Head banjo bolt size.
majik2k5
799
18
Jul 13, 2005
Lemoore, California
I'm in the middle of switching my oil feed to the head. Can anyone tell me if the banjo bolt that threads into the cylinder head is a 10mm or 12mm banjo? Also, what size bolt is needed for the oil filter housing once the feed line is removed?
The banjo bolt size is 10mmx1.25x20. For the oil filter housing you need a 3/8" BSPT plug. The Mitsu part number for this plug is MD145018. You will have to remove the adapter fitting that the stock feed line screwed into from the oil filter housing to install the plug.
