turboglenn
- 6,375
- 123
- Nov 5, 2007
RIpley,
West Virginia
Well, even an experienced tuner needs some advice now and then so here's my situation
I recently installed an aeromotive AFPR on my car ( mods list in my profile)
I am running a walbro 255lph pump ( in tank). Well, since the AFPR install I've had to increase my pulse width a ton in the 6000 RPM + range at anything over 17 PSI.
I was running a PW of 6.081 at that load bar in particular and had steady aR's at around 11.2:1
Since the install and running a BFP of 43 ( with teh 1:1 rising rate FPR ) I've had to increase my PW at the same load bar to 8.01x to get from 13.2:1 back down to around 11.4:1. Thats' about 2 full ms.
My first thoughts are... And remember a few things. I am SPEED DENSITY, NOT MAF rating the airflow, just reading from an Acurate Wideband and programming a value. I have also tested the fuel pressure to over 80 PSi and there's no leaks or signs of teh pump starting to suffer. I have done a boost leak test and the leaks are too minimal to cause this in a speed density system, the car is jsut as drivable with a blown off IC pipe thanks to speed density
A.) With the 255 pump, my stock FPR was making much more than the 61psi that the rising rate reg would put out at 18 PSI due to it's small return hole size and inconsistancy of a cheap factory part
B.) My Fuel pump has started to fail since the AFPR install. This one doens't make much sence, but anything could happen. The pump only hold it's rpessure for about a minute after powering it off ( on a factory vehicle they should not leak down for almost overnight or 8 hours )
c.) The AFPR is just a junk unit and not making a true 1:1 rise through the boost range?
The first one doesn't make sense because these injectors are good for WAY more HP than what i'm pushing at those boost levels,
The pressure holding issue doesn't mean the pump isn't flowing right, it's just a pressure control valve/ one way valve / back flow prevention valve.. how ever you want to look at it. They commonly go bad on KIA's and hyundais, but the most common symptom is hard starting so i'm not that worried about that really either.
Either way, This isn't my first AFPR, i sold my last one being hard up for cash at the time. But since the install of this one, the AFPR has been inconsistant at idle settingsby 3-5 PSI, even after tefloning EVERYTHING down to the adjuster rod. So I'm starting to wonder the AFPR is making the amount of PSI that it needs to or not. At least the price of 255's these days are Sooo much better than what i paid at the time ( 8 years ago).
But i'm maxing out pulsewidth at just about at 18 PSI, and that's just not normal. I've run this pump and injectors alone for 6 years now with no troubles what so ever. it's been through both a stock and an AEM AFPR and has never faultered. So i'm confused, I'm asking for thoughts because i'm going to be trying to solve this issue on turkeyday without pissing off my family. Hopefully some one has had this same issue and can poitn me in teh best palce to look first.
And YES, i do have bad TB seals when performing a boost leak test, but everything else is solid enough to not cause this type of A/F ratio change
