[RESOLVED] Coolant Lines for Evo III 16g
kmoore
1,241
13
Mar 8, 2006
St, Louis, Missouri
I just want to make sure I got these coolant lines hooked up correctly. Just double checking with you guys. Banjo bolts are torqued down with the crush washers installed. Just want to make sure I got these coolant lines going to the correct spots. Thanks
To be perfectly honest, I don't think it really matters which direction the coolant flows. As long as its there and able to flow. But you have it right. That's how I have them on my car. I had the same trouble when doing my 16g install. I ended up going to a dealer and finding the coolant flow sheet. (Like a parts list that has a good picture of where the lines are meant to go). So that's right.
On another note, the metal line going to your oil cooler is kinda kinked. It might just be the camera because it looks brand new.
But good luck. Looks like a nice clean setup!
Ya Kyle, thats the correct "factory" setup for the water lines. On a side note, nice clean looking setup :thumb: Was wondering is that the stock MHI evoIII actuator? Just never seen them in that silver colour before?
Is this where you mean?
It is just the camera angle...
And thanks for the help.
It sure is. And thanks... I figured since everything was out, might as well get some things powdercoated. :D
Someone went crazy with the chrome spray paint! I hope you prepped well that stuff peels easily.
