EVO III 16G water lines and oil lines??????
BOOSTIN21
413
3
Sep 22, 2003
Cedarburg, Wisconsin
ok so i will be getting a EVO 16G soon and i am wondering if i can use braided stainless steel lines for the water lines i know i can for oil. the problem i am having is finding what size lines i need the adapters and where to get them from. i have looked but have had no success. so for all the guys running S.S lines let me know what you are using and all that good stuff i already listed above. if you have pics that would be excellent. it'll give me something to drool over for a while.
oh and is there a line i can get for that bottom oil return line that runs to the oil pan?
thanks much fellas
Cullen
one of the venders, be it sbr, rre, extremepsi, etc. i believe sell the ss oil return line.
as for ss water lines, i think itd be more work and money to get it to work than what is needed. the rubber hoses and snap rings are more than sufficient.
Just re-use the 14B water lines as they bolt up directly as does the oil return line. As for the sts braided line, any turbo vendor will be able to supply one. I would just opt for a new OEM hard line since your oil supply comes from the head and not the filter housing and that's all the 16G needs.
    • george bromwell
    • pma1123
    • Sdcryan1
