turbosax2
Moderator
- 4,483
- 674
- Nov 19, 2006
Mechanicsburg,
Pennsylvania
I'm going to relocate my battery to the trunk and I want to make sure I'm compatible with road racing rules. The NASA CCR states:
By marine type battery case do they specifically want a plastic one like this or would a metal one like this be acceptable?
And for a kill switch I was planning on putting it in the rear so I can pass inspection at a drag strip (since I want to do all types of racing). But the CCR says:
Would the switch in the rear still be acceptable? I researched some and found that most cars have them near the front windows, either inside the car mounted to a roll cage (which I don't have) or outside the car in that area. Like I said, I want to be compatible for both drag and road racing, so would the rear be acceptable for road racing too as long as it's properly labeled? I'm just concerned they might consider the rear of the car an easily damaged spot.
Anybody have any insight? I don't plan on racing competitively any time soon, just doing HPDE's and autox sort of things, if that changes anything or means they're more lenient with the rules. But I still want to be legal and safe.
The battery shall be securely fastened down to the car. No Bungee cords or rubber
cords may be used to function as the sole hold down mechanism. An electrically nonconductive
material must cover the positive battery terminal. Any battery located inside
the drivers compartment shall be fully covered and firmly secured to the chassis in a
marine type battery case. True dry cell batteries may be mounted without a surrounding
case, however a case is still recommended. Note- there is a difference between dry
cells and gel cells. Gel cells still need to be mounted in a case.
An electrical master switch is recommended on all cars, and required on some, as listed
in the class rules. It shall be mounted so that it is easily accessible from the outside. If
mounted outside the cockpit, it should be mounted in an area where it is least likely to be
damage (e.g. cowling near wipers). The switch shall cut all power except to the onboard
fire system and any other life support / medical device. The switch location must
be clearly marked. Any marked switch must function as per this rule, or the indication
decal must be removed.
- Armed & Dangerous!
