FIBA M - EC17PSE
Supporting Vendor
- 6,753
- 5,159
- Nov 1, 2008
Orlando,
Florida
Hello and sorry for the topic title I didn't know what to put
! Having a few problems and need a bit of help? I've searched what I can search for the last 2days and I'm now getting the same answers so befor I go further I wand EXPERT advise from the dsm world! As you all can see I have a 97-99 gst auto nothing big in mods just uicp,greddy bov type S, manifold, coil on plug and bosch super 4 plugs.
So on thursday I was driving and car was fine but thursday night started to jump/sputter/jerk/bogs hard to say but doing those kind of things and doesn't gain much power its never done this before and its not a boost leak as I've checked all the clamps fixings etc.
On my searches I've found these what it could be! They are:
Air filter/fuel filter
Ignition
Oxygen sensor
Egr system
Torque converter
Wastegate
Spark plugs
Injectors
Auto filter/ bands?? Seals??
These are what people say but its a big list so any other options? Recently done an oil change moble 1 as allways every 6 months cambelt done 8 k miles ago everything done with new coolant etc also noticed a little white smoke a few times 3 times recently only and it has rained on them days so could it be that cause the condensation for smoke? I have a cel light have done for about 2 months but goes away for ages then flickers on and then off again so everytime I try to read a code they can't coz it goes
but its stayed on now and gona get the code looked at on monday hopefully! The gears are selecting ok and o/d works but just jumps etc when you give it gas!
I would really be thankful for any helpfull input and sorry for the newbie part but I'm not to up on the small terms like bs eliminator
so please could you word them as normal if possible hehe thanks and I hope to sort this very soon. If you need more info that you need to know or I've forgot then sorry I will answer and help as much as I can also thanks again bobby
! Having a few problems and need a bit of help? I've searched what I can search for the last 2days and I'm now getting the same answers so befor I go further I wand EXPERT advise from the dsm world! As you all can see I have a 97-99 gst auto nothing big in mods just uicp,greddy bov type S, manifold, coil on plug and bosch super 4 plugs. So on thursday I was driving and car was fine but thursday night started to jump/sputter/jerk/bogs hard to say but doing those kind of things and doesn't gain much power its never done this before and its not a boost leak as I've checked all the clamps fixings etc.
Ignition
Oxygen sensor
Egr system
Torque converter
Wastegate
Spark plugs
Injectors
but its stayed on now and gona get the code looked at on monday hopefully! The gears are selecting ok and o/d works but just jumps etc when you give it gas! I would really be thankful for any helpfull input and sorry for the newbie part but I'm not to up on the small terms like bs eliminator
) ? that is often an ignition malfunction. def get the ngk plugs!!! replace your wires also while your at it. are you under stock boost? i had a stutter at wot and slight misfire at idle and when I replaced my plugs and wires she ran like a champ.
