[RESOLVED] 2g wiring question, temperature sender hookup.
rabenne
1,803
843
Apr 21, 2006
Racine, Wisconsin
The ECU coolant temperature sensor has a black two wire plug connector on it. One wire is black and the other is black with a white stripe. I need to know where these wires are on the plug? With the release button facing up, which wire is on the left and which is on the right? Please take a look under the hood and help me out. My connector broke where the wire is joined with the terminal inside the connector. Just need to know which one goes where, THANKS!
thats what I was thinking but I am trying to do everything as "correctly" as possible. I did check into that sensor a bit more, and it does not in fact matter which way you hook it up... I really do appritiate your post though, I can wire it up like origional!! THANKS
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
