[RESOLVED] Temperature Issues
Kab2400
Sep 25, 2008
Phoenix, Arizona
Hi all,
My temperature keeps fluctuating. It starts and normal temp, then it randomly will start to heat up, and then the temperature gauge needle will go up and down, up and down. Also, it seems to go down when you accelerate, it will even go down if you accelerate in nuetral.
I have replaced the water pump, the radiator, the radiator hoses, the radiator cap, the thermostat, the temp sensor. I have flushed the new radiator to make sure there are no clogs. I'm at a loss. The fans are working properly.
Any thoughts or suggestions? Thank you.
I have a '97 GST Spyder.
Honestly, it sounds like a couple things here. Despite what you say you have done...
1. You could try a 170 degree thermostat.
2. Could be a faulty water pump.
3. Fans are not working properly.
4. An issue with your head gasket.
5. You have a large amount of air in your lines.
Those are my suggestions despite what you have said you have replaced.
Or you may simply need to add more Coolant. I had the same issue and come to find out, I was low. I had pockets running through my system, and everytime the air got pulled through the engine, it heated up.
I'm such a noob, the problems were all caused by a bad battery. Go figure.
Hi all,
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
