Replacing rear 02 sensor
Jason97GS-T
186
Jul 14, 2008
North Bend, Washington
I went to get my new exhuast put on my car and they said that the rear 02 sensor is striped and that if they took it off they could not get it back on. So now I need a new sensor. I have seen prices range from $35.00 to $100.00, but I dont know which one is the right one. Can some some one please post a link to the one that I would need?
Thank you,
Jason
the brand doesn't matter its the "universal" or "oem" that you want to look for... if you go for the cheap universal it won't have the OEM connector on it so you'll be splicing wires after you cut the connector off of your old o2 sensor. usually OEM rear o2 sensors go for $75 and the brand is bosch.
:dsm:
No problem, its pretty easy to install and shouldnt take more than 30 minutes tops....
1st, Disconnect battery negative (just make sure you can get to all the bolts/nuts if you have power....)
2nd, Remove 2 bolts and 2 nuts holding driver seat in place...
3rd, Disconnect electical connections under the seat...(If power seats)
4th, Disconnect o2 sensor wire under seat/carpet...
5th, Jack up car, and get an o2 sensor socket on the sensor...Unscrew it...and pulled wiring out from inside of car
6th, Add good antiseize not crappy ass napa/advance/autozone junk...with a copper or nickle base....
7th, Screw sensor in then route wiring up threw the hole where you pulled it out from...
8th, Plug sensor back in, and reconnect the seats electrical plugs(If power)
9th, Bolt seat in
10th, Put negative back on...(since the battery was disconnect it will clear all your radio stations LOL and all CEL codes....
Enjoy the feeling of boost..LOL...
