Rear 02 sensor
markp
44
Feb 17, 2008
St louis, Missouri
I'm in the process of removing my rear 02 sensor but am having some trouble finding the connection in the car and I'm also having trouble getting this metal clip on the wires underneath the car right before the big rubber grommet which is preventing me from pulling the wires through. Can anyone tell me where the connection is in the car, under the driver's seat under the carpet or center console, and how to take off this metal clip? Thanks
Well, you might be able to unplug it by just taking off the center console and the drivers side console shield (dont know name), then if you sit in the chair its right between where the center console should be and your seat...and it is under the carpet
thanks for the input. Any ideas about the clip I mentioned? It clamps over the wiring on the underside of the car right before the rubber grommet, preventing me from pulling any wiring through.
Why do you need to remove the metal clip? The only way to remove the sensor really is to unlug the harness, unplug sensor. Then your suppose to just pull it out from underneath the car but there is a another plastic clip that goes around the hole that prevents the harness to pass through the hole... with a flat head screw driver push in the sides of the plastic clip and it pops out... hope that helps...the best way to do this is buy removing the seat...its just 4 bolts
