removed rear 02 sensor ?
dsm4life
1,323
3
Sep 24, 2002
Philadelphia, Pennsylvania
im getting cel with no cat. with OOBII If i remove the rear sensor will i still get CEL
Unscrew the sensor but leave it plugged in. Zip tie the sensor up out of the way and plug the hole with something. An old sparkplug works, or any bolt with the same threads as a sparkplug. Reset the ECU and unless your car is really picky you shouldn't get the CEL again.
Coup D E'Tat said:
Yea, mine is wrapped in tin foil and wedged underneath the car, and works fine.
thanks guys i found a few post with the same things, Im going to try that , thanks :thumb:
