Replacement dash lighting?
Doubletake
92
Nov 21, 2002
Winnipeg,
Where can i pick up theose special plastic base bulbs for the gauge cluster back lighting, Also when i took the hazards switch apart , the little bulb inside was burnt out, is it possile to only purchase the bulb?,..the swith still works.
Thanks
Matt
LED = Look Very Nice
We have these done on my brother's 92 talon. All of the siwtches are done behind the HVAC minus the A/C switch due to it's color change light that we didn't want to deal with. All the lights behind your instrument cluster can be replaced with LEDs as well for a very nice look. Word of caution, if you replace the LEDs behind the HVAC then you will want to replace them with high grade LEDs, some LEDs are good and will last awhile, some won't. Be willing to spend the extra dollar so you don't have to replace these things within a few months.
Or you can be a total cheap ass. For my 89' Jeep Cherokee XJ the lighting was just plain ol' white. So I bought Candy Apple Blue spray from AutoZone for like $5 and put only ONE coat on the bulbs. Why pay almost $3 a pair from companies like APC when they do the same thing?!?!?
