replace idler pulley help
boostin_93
Aug 5, 2011
sioux falls, South Dakota
i have a rattle coming from my timing area assuming its the idler pulley is that an easy replace or a nightmare to get to? the rattle goes away at 2500 or when it boosts but if i set the cruise i hear faintly any helpful info?
With all the info and pictures on this site and VFAQ.com, anybody can do a timing job on a 4g63.
I never have done one before either, after following the writeups I've done no less than 15-20 now.
The timing Belt is doable just follow the Vfaq, but what your describing dosent sound like the idler pulley.
FWIW -- I had a rattle in that area and was afraid it was under the timing cover, but I felt around in the vicinity and found a loose bolt at the A/C belt idler pulley. After tightening it the rattle was gone, but not too long afterwards I started hearing a squeal from the same area. At first I thought it was an A/C belt tension issue, but turned out the idler bearing was shot. Replacing the idler ended the problems. My point being there are other possible causes for noises in that area.
