Idler Pulley?
Tal95er
44
Aug 4, 2003
Hey guys,
For about a week now I have been having rattling problem right near my belts. I know it is a pulley and what pulley it is but I have no idea on how to replace it. The pulley that is making the noise is the pulley is on the same belt as the crank/AC. I think the shop said it was the idler pulley. Is that right. How do I go abot replacing this one. I couldn't find any faqs on it either so any help would be appreciated.
Mike
It's called the tension pulley and is mounted to the tension pulley bracket. You remove the whole thing and then replace the pulley on the bracket. Remove by loosing both tension bracket bolts, loosen belt tension adjustment screw till belt is loose, and then remove the 2 bolts.
Originally posted by Tal95er
Hey guys,
QUICKLY - before you destroy the sumbitch!
http://www.vfaq.com/mods/timingbelt-2G.html
