Repairing a T25 Wastegate?
thach
52
Nov 13, 2010
Buffalo, New York
The wastegate on my t25 has a little issue. The part that connects to the turbo via a rubber hose is broken off. Is there a remedy for this or would i be better off simply getting a different one?
here are some pics:
You can try tapping in a fitting like the one in the picture I send. I should mention the fitting is resting in 1/8 inch thick material and is perfectly flush on the inside. the fitting does not protude. It looks like you might have some thickness to work with. I would also suggest using high temp locktight to hold it in.
Bump
I ran into another issue related to the wastegate! the little clip that holds the arm onto the actuator broke...can i go to the dealer to get another or is there some good alternative?
huh, i searched "couter pin" and google gave me results for "cotter pin." is that what you meant?
Go to your local R/C hobby shop. Look in the airplane section and you'll find some fittings for R/C engine carbs. They use a very small thread with a barb on the other end. You should be able to find one small enough to tap into that hole without it protruding through.
Look for something like this:
