removing trim kit....
mike1999
150
Jun 10, 2005
oakland, Maine
when i got bought my car it had a carbon fiber trim kit for the interior and i did not like this so i ripped most of it off with the assistance of a friend of mine while we were driving down the road..... the only problem is that when you remove it it leaves crappy looking glue spots what can i use that would effectively remove this stuff?
alright is this stuff common so i could just go to walmart or something?
Actually, you know what.....
I'm not sure how tough that stuff really is. It may or may not actually remove the color from the dash. I would try windex first.... the glass cleaner. If that doesn't work, then try some goo gone on a part of your dash that you wouldn't mind not having a little bit of color missing. Yeah, you can pick it up everywhere.
alright i will do that.... that would suck if it killed my dash haha
If its just the vinyl stickers, a heat gun/blow dryer may work as well. I applied the kit awhile go and decided it looked cheezy and it all just peeled back off without effort.
You can always rub it off with a light coating of WD-40 and then go over it with some windex to remove the oily film from the WD, WD works wonders for removing adhesives.
