removing rear window trim?
volcomsnow245
492
May 4, 2011
chicago, Illinois
Ok guys I searched and still can't find how to do this. I'm trying to remove the trim on the back of the rear window so I can redo the seal so water stops getting in. I just need to know how to take it off.
thanks
I popped mine off and pulled all around it isnt easy the trim pieces are easy everything else just start pulling its kinda hard to explain whats the problem.
I removed the strip when I painted my 95 and I'm not 100% sure but it seems to me that once removed, it needs to be replaced with a new one. If anyone knows out there, chime in for us.
The upper and lower trim pieces are held in with clips. The upper piece may partially be glued in. If this is the case, you'll most likely ruin the trim removing. If it comes out, you'll most likely need new clips as they are fragile. The lower molding will snap out. Somewhat harder to describe, I believe you start with the glass side, then bottom to remove. The side trim pieces most likely have window sealant holding them in as well as they are kinda press fit on the glass. Most if not all of these trim pieces aren't avalible anymore from the dealer.
