removing 1g trunk trim panels?
s1ngle
Jul 7, 2005
Minneapolis, Minnesota
Having a hard time figuring out where everything is secured, and I dont want to break or damage anything.
Can anyone post a service manual PDF or anything on the subject of removing trunk trim panels in a 92 talon TSi?
Thanks!
edit:
I'm having trouble getting the rear shoulder belt covers off, I can't figure out how they pop off and I dont want to break anything. I'm also having trouble getting the piece in the very back, the part that covers the hatch latch (I rhymed!). I took the 4 top fasteners off, and the two screws at each bottom corner. What do I do now.
The shoulder belt covers just pop off. Use a little force and they come right off. As far as the rear center panel, you also have to remove the tail light access covers and remove the screws behind them along with the two on the bottom.
Thanks for the advice!
I thought I got all visible screws/fasteners off the back trunk piece... are there non-visible snaps that require me just tugging on the piece to get it off, or should everything be visible?
Which side of the belt covers should i pull on, the side near the window or the side on the inside?
GRRRRR... I wish I just had the service manual diagram. Then it would probably be self explanatory.
