goldeninja20
- 589
- 3
- Dec 5, 2010
Norton,
Massachusetts
I have been trying to figure out why my shifter has felt very sloppy. I have the solid bases and also the skateboard bearings on the transmission. I took the shifter base and swapped it with another and the same problem is still occuring. My problem: When you put the car in first gear and then take it out of gear and put in neutral, it will not go back to the middle position of neutral. It is very hard to figure out if i am in first gear or in third gear. It has something to do with the levers on the transmission because i took the linkage off of the transmission. When i was moving the levers by hand, i could tell that it is very sloppy. I have heard that you should remove the levers and grease them and clean them up. I am not sure how to do this, and is this my problem?
