Removing some vacuum. advice needed
Re4peR26
74
Jan 10, 2008
Ravenna, Ohio
Today i blocked off the green and yellow vaccume lines running the the vaccume port on the thermostat housing.. Now here is the question am i only supposed to block the ones off on the throttle body becasue i see some others leading twords the firewall... What other lines can i eliminate to help the car brethe better, maybe even run better?
My bad I blocked the one on the throttle body leading to the thermostat
i took just about every single line i could find off, im doing that egr block off plate soon as well. you can follow this guide
Tech Guide: 1G 4G63t Upgrades: Stage 0 Power - DSMtuners
Some of the links do not work.. But im going to go through with all this. I Do have to worry about emssions but oh well ill get exempt with 300 in recipts for emissions stuff LOL..
