Removing Oil filter coolant assembly (Stud replacement)
91talon91
69
Jun 3, 2012
Gville, Florida
I am running an oil cooled turbo and want to delete the oil filter coolant assembly. Anyone have a part number for a stud I could run in place? NT stud?
Thanks, Jeff
Assuming you need this on a 1G, you will have to replace the oil filter housing with one from a N/T car and plug the two water lines that go to it in order to remove the cooler. Or you could shorten the existing 'stud' removing from the housing threaded side as much as the width of the oil cooler.
http://www.dsmtuners.com/threads/simply-way-to-gain-some-downpipe-clearance.448757/
I would replace the oil filter housing, but that's me.
  • Wanted 1g Chassis harnes fuse box
    • 92AWDHX40
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
