Remove this coolant line?
KFred 513
146
Oct 11, 2012
SUllivan, New York
So I'm wondering if i can remove this water line? It runs right down to the water pipe currently, not sure where it goes from the factory. I don't see any problem removing it, but I'd rather double check quick.
My mistake, that is the engine oil cooler feed. Got confused because I don't have that on my 90.
Thanks again for clarification, the diagram backs you up.
That nipple goes to the 2g coolant overflow tank.
I am not sure why its rerouted on a 2g. Do you currently have an overflow thank?
I have an overflow tank, it is on the other side, above the radiator cap seal so that coolant isn't always flowing through the port.
Thanks for the diagram crimson
