RJ_IS_BATMAN
- 105
- 19
- May 7, 2020
Ontario,
California
Hey Everyone!
Working on my first DSM and the car had been sitting under a tree for a year. Owner said that it had started fine when it was parked but due to a bad transmission cable he just parked it and never tried it again.
I checked the engine oil and it looks clean no issues i can tell. I was wondering what you guys recommend i replace prior to attempting to start up the car?
I was thinking of doing spark plugs, oil filter, oil, coolant flush, spark plug wires, and the ignition coil.. Is there anything else i should look at or for prior to attempting to start it up for the first time?
. Alright so if the car is a gst or gsx take off the intake pipe to the turbo inlet. Make sure there are no obstructions or crap in the filter and check for turbo shaft play. Make sure no oil is puking from the seals as well and make sure it spins freely. Like I already said, make sure you turn it over without starting it so you can get the fluids running. If you want to you can unhinge the lever on the waste gate so it wont build boost.
