4gfun
Supporting VIP
- 2,009
- 56
- Dec 10, 2007
Ask Me,
Virginia
I decided to follow one of the procedures to rebuild the throttle body using milspec seals. There are no boost leaks on the throttle body.
When I was rebuilding the throttle body, I carefully marked how I took it apart and then like an idiot cleaned it up with throttle body cleaner forgetting that I marked it.
I would like to know which parts would cause an issue if installed backwards.
I know the throttle plate can be installed incorrectly, but what about the throttle shaft? As long as the ends of it go to the throttle cable and the TPS I don't see how that could be wrong.
What else could be wrong? I etched markings into the throttle plate before installing it so I think that would be right.
The car idled just fine before I started the rebuild (due to leaky shaft seals).
TPS is set at 10% per MMCD.
The throttle plate doesn't stick and is fully closed. The BISS screw doesn't leak and is fully in like it was before I rebuilt it. I never went into the FIAV either.
Thanks
Thanks
...just the cheap side of me..most of us here have it
