Rebuilding the bottom end. Can anyone give me some ideas?
vteckiller92tsi
55
Feb 5, 2011
alanta, Georgia
I need some help on the bottom end rebuild. I need to know if it is better to use custom 1g rods with 2g pistons? Or to use standard oem pistons? I know that the 2g pistons will give me 8:5:1 compression where the oem only gives you 7:8:1 compression. But has anyone in here done this did it cause any trouble? And i would also like to know is the balance shaft eliminator kit.Is a good purchase and if it is a pain in the butt with the motor out.And by the way this is a 91 eagle talon tsi bone stock! Everyones input helps thanks.
I want decent power not to much that i have to use racing gas. Just enough to be suprising. I would love to have alot more but my wallet says i can't.And as wallet i meen wife ROFL.
id definitely go with the 2g pistons and 1g big rods with arp rod bolts. Easily be suitable for 400hp with a good tune
i agree with whats said above 2g or evo9 pistons are good enough with 1g rods with arp bolts for 400 to 450. pretty much anything youd want to do on pump gas with a street turbo. good luck
Yes - just replaced the block with a similar target in mind. *DO* the balance shaft elimination kit. Failure of the front shaft bearings at 126K was the reason I was forced to swap out the block.
According to my calculations, 8.5:1 was about as high as I wanted to go and not have to constantly feed it a special fuel diet.
Also, look carefully at the two bolt holes facing the driver towards the front of the block where the left axle and AC compressor bolt onto the bottom of the block. The front bolt was broken off on the old block, and BOTH had broken off bolts inside them on the replacement block. MUCH easier to deal with this BEFORE the engine goes back in the car. (I didn't notice that in time, assumed new block $2Khad no problems = wrong!)
You'll of course also find other things you'll want to do while it is apart such as:
Heftier clutch?
Cams/springs? (I did just the springs so I can do the cams later without pulling the head again.)
Motor mounts?
Replace hard to access rubber - like that hose behind the exhaust manifold.
Etc., etc.
Have fun!
Be sure to use ARP rod bolts. Have the machine shop shotpeen your rods. You should probably use a new oil pump assy and water pump while you are at it.
Parts Dinosaur is fairly priced for a budget rebuild. They have about all the parts you will need including piston and ring packages.
Regards
Greg
If you are not planning on buying a tuning solution that can alter the timing map, 8.5:1 compression can have some issues on a stock 1g timing map, that is aggressively tuned for a low 7.8:1 ratio.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
