rebuild my engine ,which parts for good combo?
gsx tuningart
80
3
Jan 18, 2005
Viterbo, Europe
I have many parts to rebuild the engine.
My car is a 95gsx and my goal is 450/500 whp.
the base is a short block 6 bolts .
I have at home the following parts :
eagle h beam rod 1g and rod 2g
arias pistons in 85.5 (020) for 2g with compression ratio 8:5:1
and 86(040) for 1g with a compression ratio of 8 : 8 : 1 ,
Cometic head gasket with standard thickness and 1.6mm thick
550rc injector or bosh 720 ,
aem fuel rail with fuel pressure regulator , walbro 255
1g std head , 1g ported head , and 2g std head.
intake manifold 1g , 2g and magnus sheetmetal for 1g,but i can mod this for 2g just in case.
hks camshaft with adjustable pulleys ,
tubular DNP exhaust manifold with external wastgate and tubular exhaust for big16g .
CLUTCH MASTERS ALUMINUM FLYWHEEL with act extreme street disk or ACT XTREME SPRUNG 6 - PUCK .
what would you think the best combination ?
I can not buy
other parts , so I have to build the engine with this .
thanks to everyone for any consideration on this.
I'd use the 1g rods with .020 over pistons. Bosh 720 injectors. 1g ported head. magnus intake mani(make sure its port matched). Exhaust mani just depends on what turbo you want.
Put some good rod and main bearings in. This engine will be good for more that 500whp but its always good to stay safe. Good luck
Thanks for your input, i had acl race rod and main bearing ,ma this time i want to go with king xp .
I have fresh overhauling big 16g and other turbo that i don't know what is this.you can see here:
Well the big 16g will not get you 450-500 whp, and on e85 (if that is what you will use) you will be looking at more than 720cc injectors to reach 500bhp. You can build an engine with what you have, provided you have the rest of the bits not listed, but I also did not see a tuning solution listed. Do you have link, black box, or a standalone?
I know that the big16 is small for my range hp, but i can't buy other turbo now. Airesearch is E85?
For engine managment, i have ecmlink v3.
I have also 1g TB, downpipe and cat back " 3" , all security guage in my board and other stuff.
Thanks for your answer.
Go with DSMlink if you don't already have one. Its so worth the money! I had ecuflash and yes its a lot cheaper but it kicked my butt. Standalone systems are very expensive and honestly have way too much crap you can change. DSMlink full is all you'll ever need(pretty sure its taken guys into the 8s).
Also make sure you have good head studs because that would suck to build this nasty motor and hydrolock it or something because the head and block separated.
I'd recommend a main girdle too.
