Rear subframe bushings too short?
but
190
Apr 7, 2009
Ridgecrest, California
I burned the old bushings off the rear subframe,i went to put the new ones from energy suspension in and they only go up halfway of the inside of the mount. Is this normal? The other mounts that are attacthed to the back of the rear diff are perfect. its just the two.
other wise they sent 2 of the wrong bushings or you can mod them to get them to work. get a peice of steel tubing the same size of the one sent with the bushings. the the bushing in 2 to make to caps and use urathain filler in between. put 1 cap in put the metal shaft in fill the apropreate amount of urathain in the middle of the bushing and press the last cap on the other side. let it sit and cure fully then install on your car.
