2G rear subframe bushings
cj8990
97
Mar 20, 2010
Chicago, Illinois
anyone have a part number for rear subframe bushings? searched around and couldnt find it anywhere.... the bushings between the chassis and the subframe.. not the ones on the differential
thanks
corey
I'm almost 100% sure there are not OEM replacement bushing.
If you search around here, you should find vendors who offer aftermarket solid or poly replacement bushings. At least for AWD cars, not sure if there is a difference for the FWDs.
Are you looking for OEM?
Try the dealer, they can order them for you.
there are not oem replacements. to replace them you have to replace the whole subframe.
luckily some crafty person at tuners nation saw this lack and made sets of press in style poly bushings.
He is no talking about the Frame Bushings, He is talking about the Washer style that goes in between the (Frame and Subframe).
I bought My Bushings from the dealer and they had it on stock.
I do know, they don't sell the INNER Bushings (that goes into the Subframe).
They do told me, they come with the subframe.
If you read the first post.
He is talking about the bushings that goes in between the sub and frame.
