Rear motor mount replacement, 2g awd
Jammin'Trey
74
Jun 11, 2009
Omaha, Nebraska
Hey I need to replace my rear motor mount on my 99 gsx, I can see that it is torn up and I can feel the motor clunk when I am driving. Are there any tricks to putting a new one...? Do I have to drop my transfer case? Thanks in advance....
You should be able to jack the car up with a strong jack, put some jack stands under the car and remove the bolts in the mount. After that you can jack the tranny side up or lower the tranny side down if it's easier and replace the mount. It shouldn't take that long to do.
with my GST, i just supported the engine with a small jack, took out the battery and tray, and switched out the mounts. you shouldn't have to jack the car up or take anything off far I'm aware.
If you have the right tools and skinny arms, you can do it all from the top. That's what I did when I put my Prothanes in. Never even lifted the car.
I probably wont have either LOL... I will try.
I was in the same boat as you. This is how I did mine.
1. Jack up the car put it on jack stands.
2. Take out the battery and plate
3. Use a couple of 12" extentions and you can reach the bolts for the top.
4. Jack up so that you can take the bolt out of the motor mount.
Thats it I think it took me about 15 minutes at the most to replace mine.
The drivers side rear is stuck, I have been using a 14mm snapon swivel with a 1/2in snap on impact and its not budging, I am doing this all from the top of the engine bay. I found some vacuum lines laying!!! in my engine bay, I think I know why my vacuum at idle is 15in mercury...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
