whats up
- 0
- Feb 14, 2023
Kansas
I'm converting my 97 GS with a LS swap, I got a AWD rear diff from a 2g GSX. Is there splined hubs I can use on the original GS rear knuckles that will link up with the GSX diff
Fwd and awd rear knuckles and hubs are different. You CANNOT make any awd rear axle system fit a fwd rear knuckle its impossible! Grab an awd rear knuckle as i said and a bearing that suits and you will be on the way to getting this resolved alot fasterYea i seen that the front and back hubs were different but i was just wondering if someone found some hubs that fit the orginal knuckles for the gs, i seen some on ebay that match pretty close in diameter, bolt pattern, and everything but they are for some other make and model, just didnt know ty
97-99 are deeper so opt for those ones. Only model thats awd in the USA that use these i know of so has to be from a 2G DSMIght ill use it, so does the rear knuckle have to be off a 95-99 gsx or is there other models that have the same rear knuckles
