rear eccentric bolts
98awdturbo
61
Dec 9, 2010
Waterford, Michigan
Is there anywhere current to get the rear eccentric bolts for a 1G? Searching i could only find threads that have dealer part numbers and all dealers by me say they are out of production. Any help would be great. thanks!
MB515167 ? That's the number I get from CAPS.
Call Josh @ JNZ, they list it as available, for $5.44. JNZ Tuning - 215.997.6850
it says rear suspension bolt but doesnt really specify if its the eccentric bolt. Ill call there tomorrow. Thanks for the quick reply
I've ordered a couple sets of eccentric bolts, eccentric washers, lock washers and nuts from JNZ. Sucks when the stockers are siezed.
good deal. got all the numbers will order them tomorrow from JNZ. Worst part is I was able to get them out with a little heat and persuasion. The threads chased fine too, just the eccentric cam rings ended up being warped and wont sit in the socket properly. figures. Thanks guys!
I'm not sure which bolts you are looking at, upper control arm for camber? However I believe whiteline makes some eccentric poly bushings for that application.
This is a common problem on the 1G cars, and Ive had to cut all 4 of the eccentrics before. Just put antiseize on the shafts and threads of the new bolts and on the backsides of the rings and also run a properly sized drill bit (I think it was 9/16?) lubed with PB Blaster through the metal sleeves within the bushings to clean the rust out before putting the replacement bolts back in:thumb:
I put poly bushings in so the sleeves are new. but for sure putting anti-seize on the bolts. I don't ever what to have to go through this again if it needs to come apart.
