1g rear toe eccentric replacement?
Rex2342
788
12
Aug 30, 2004
Mckeesport, Pennsylvania
I've been searching for this for a while but every thread seems to point me in the same wrong direction. I'm going to be doing a bushing install finally and will be doing the rear subframe bushings with my 4 bolt swap and every other bushing I can find too. However I can't seem to find a replacement for my rear toe eccentrics. Every thread that comes up in the search says to use the jay racing active rear toe eliminator but this isn't what I'm looking for. I need the eccentric for the factory toe adjustments. I know for a fact these bolts are seized and will have to be cut out. I've been soaking them for years( yes years LOL ) and every time I do my alignment I try to move them but they won't budge. I found the camber eccentrics on extremepsi but still need the other ones. If anybody can help me out it would be much appreciated .
I think I confused myself in all my searching. For some reason I was thinking I didn't have the bushing for the rear lower control arm. I'm looking for the eccentric bolts for the camber and toe adjustments so that after the bushing install I can finally adjust my rear toe and camber.
I just got used bolts from DSM Graveyard.
have you tried specialty products? If I can remember, I will look though the catalog when I get back to work on monday
So my quest for this hardware has led me to the dealership. After several days of getting the run around I finally found someone willing to help me out. We managed to find everything I needed to get this done right. It turns out the eccentric bolts are the same for the camber and toe adjustments. I wasn't sure if they'd be different sizes or what but they are the same. Here are the part numbers for anybody else needing them. You'll need 4 of each to do the whole rear end. it cost me $26 and they will be here Thursday.:hellyeah:
MB515167 - Bolt
MB303958 - Nut
MB111440 - Eccentric Plate
MS450045 - Lock Washer
It took me forever to find someone willing to help me out. I have 3 Mitsu dealers near me and all but the one gave me shit about getting these. They asked me 10,000 questions that weren't even relevant to what I was looking for and when I wasn't sure of an answer they would say they needed to know in order to get the parts. The last guy just printed me out an exploded view of the rear suspension and I was able to locate them there and he punched them in and ordered them.
