dgdsm
- 177
- 4
- Aug 24, 2008
Tarzana,
California
So after chewing through rear tires for about 5 years, I have now started to do my own alignments. I'm using two methods, the toe plate method and a laser level method I found on YouTube. I might also do a string alignment sometime. Both the front and the rear are now within specs (0.06 inch toe-out) and it's driving straighter than it has in a few years. We'll see how it holds up. According to a frame/ alignment shop I took it to a few years ago, any alignment work done on it wouldn't hold because of worn-out bushings. I think I have now what I need to replace bushings, or just entire control arms one by one. I don't know about subframe bushings.
There is though currently an odd thing: The rear eccentric toe bolt is 180 degrees out from the mating mark (see image). It's the same on the other side. Turning the bolt so that the marks are lined up in the right orientation doesn't leave the toe where it needs to be (outside adjustable range). Could it possibly have been installed incorrectly by a previous owner? Should I take it out and reinstall it, or replace it? Or just leave it?
