Rear CV Axle Assembly
hardzy32
May 11, 2008
Putnam, Connecticut
Quick Question.. I cannot find a rear cv axle assembly anywhere. and am curious are the fronts and rears the same? or can anyone point me in the right direction as to where i can pick on up. ive checked raxles but if anyone has an other ideas or can fill me in on if they are the same that would be great. Thanks:talon:
You can't interchange any axle on a DSM front to rear side to side etc. All four are different.
First off you need to determine which rear axles you have: 3 bolt flange or 4 bolt flange.
Then specify drivers side or passenger side.
Your best bet on getting a rear axle is a junkyard, partout, or try DSM Graveyard - Your #1 Source for Used DSM Parts! , I got an axle off them last year at the Shootout and they are also a vendor on here.
Hello there, i am now on the same situation as you. Any update or any information regarding this? I know i am bumping on an old thread. Thanks.
