Rattle from Passenger Front Wheel
GeneralCole
Jul 8, 2011
Las Cruces, New Mexico
I recently purchased a 95 GS-T and am fairly new to the vehicle. I have done some research and feel like the wheel bearing may be at fault. There is a lot of vibration coming from the front passenger wheel when I get up to about 60. From what I read here, it sounds like a wheel bearing, but I also know that the whole car sits lower on the passenger side. I'm buying coil-overs soon and was wondering what else I should look into purchasing to ensure that this problem goes away. Thank you for your time!
STOCK DRIVETRAIN
FWD
Just to add on to that. A rule of thumb with bad bearings is that they tend to change pitch as the speed picks up. From the inside of the car it almost sounds like you have thick off road treads on one of your wheels.
YEah if you are getting a howl or a roar you may have a bad wheel bearing, but if no noise it could be as little as your wheels need rebalanced. Oh is that tire wearing funny?
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
