MikeyTsi
- 147
- 9
- Sep 30, 2007
Renton,
Washington
Car - 1995 Talon TSi AWD (has my '97 drivetrain in it)
mostly stock, unstock stuff is hard pipes, Hallman MBC, mechanical boost gauge, high output alternator (we ran an additional power wire so we wouldn't have to mess with the stock wiring)
I've got an issue that's starting to get progressively worse where it appears the car is randomly dying when not on throttle (engine braking or sitting at idle). Had it happen a few times when on the freeway, at that point pressing on the throttle got it going again. Had a few issues where it would die at a stoplight, first time it took a few tries to get it going again (it would immediately start then immediately die). A few days ago it died while driving and took a good 5 seconds for it to start up again under "bump starting" (it was already moving). Tonight it took a good minute or so to get it to start (using the key since I was stopped). It also died a second time on the freeway, but kicked back on immediately when I pressed the throttle.
No engine codes. I've recently installed Torque Pro, but it looks like the links for the 2G apks aren't valid (the one I found doesn't appear to have any 4G63 options), and it looks like my ancient BT OBDII module is too old anyway
When I was messing with it last weekend it would pretty reliably die at idle but would immediately start up again. Wiggling cables and connectors didn't seem to change behavior
Other issues I'm seeing (which may or may not be related):
- If I drive somewhere and get out for like 10-15 minutes the car has trouble maintaining idle on its own unless I put the throttle in it a bit; it'll start up then rpm drops immediately and it struggles or dies. Once it's going though it's fine (I'm assuming I need to re-do base idle adjustment)
- If I drive somewhere and am out of the car for like 2-3 hours, Upon restart I've been pretty regularly getting something that seems like light vapor lock. Not sure what that issue is.
Any thoughts on what might be causing this?
