Random Plug Help
alexsimpson440
May 15, 2014
Anoka, Minnesota
I was looking in my engine bay and I found a random plug that was not plugged in. I took some pictures. I also found a 1g active wiring diagram that I will post. From that diagram I believe it is AT related, I dont know what that means, or b16 ac clutch. But I do think it is more AT related. In the pictures, red it the exact wire and green is where it is leading to. http://tech.mirage-performance.com/1GDSMharness/1G-DSM-4g63EngineHarness.html That is the link to the diagram. You can click on each plug and it will bring you to more pictures. I just want to know what the plug is, and if it should be plugged in. What is its purpose.
Do you have A/C? That could be the compressor plug.
That would have been my next guess also...and important!!!
Thanks Brian!
The PO of my car had deleted mine and my cruise but luckly left every connector alone. I was pretty sure I had seen that plug on mine too, but I don't know the exact location for it to plug in but should be on the side or back of the compressor.
It is used to help the ECU maintain idle when the A/C is being used.
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
