joe sobo
- 846
- 1
- Dec 30, 2007
stuart,
Virginia
i did a full restoration on my car, but the last bug to work out is that SOMETIMES when i go to hit boost, the car will just sputter.if i floor it while it is sputtering, my a/f dosen't start to get pig rich. i do not have a good a/f, but instead have the pen type turbo timer.just cruising out of boost, the car runs at about 14.7, and when i floor it, it richens up to like 10.0:1. so i know these are not that accurate, and im not running extreme boost.(stock boost level on a 14b installed on a 2g). i have ported manifold, 3" turbo back.
i replaced the plugs about 2 weeks ago, with the wires and everything else.
would a bad, or going bad o2 sensor be at fault? but i have no check engine light for it.
once it starts to sputter, and i let off the gas to let it go back into vacuum, then hit the gas again, then it will be fine and boost perfectly with out sputtering.
would be great if someone can point me in the right direction thanks
