2G random injector misfiring
AlexGsxCummins
395
38
May 31, 2014
Bremerton, Washington
So, what it seems like so far is that a random injector will lose its signal. Last week I had a random misfire code. Found out it was injector number 2 not firing. Now today injector number 4 stopped working. I forgot to check the continuity on the injector itself while the issue is happening but the 12v signal is defiantly dropping in and out. I shut the car off and checked the resistor box and it checked fine on all pins. Restart the car and it runs perfect. Any ideas?
Dsmlink somehow had misfire unchecked in dtcs. I have a 1g Cas so I'm going to guess that was my issue for this problem. Still got to figure out why it goes lean for a split second when accelerating
