Random connecter
jdm9221
125
5
Apr 10, 2017
Osceola, Indiana
After taking the head off for a new head gasket I've ran into a few problems I mainly have 3 questions. How many lines come from the water pipe. I have 5 connected(front right one is plugged, front left is coolant for turbo, 2 under the filler neck go to the throttle body and the back one goes to the heater core however I found an extra line that I'm not sure where it goes, it may be an extra I had that accidentally got tossed into the pile but I wanna make sure before I start it.
Secondly since I am now running an evo 8 ecu and maf I was told I could delete all the vacuum lines from the throttle body and plug them off,then tell the ecu and it should run fine,I want to make sure before I take them off and realize I will still need them. I know I obviously need vaccum for the bov and fpr but are the others ok to get rid of and tune for on evo 8 ecu
Third and final question is I have a single pin connecter that I cannot track down where it goes, it seems to be close to the filler neck and coolant sensors but I don't see where it plugs in. Any help is appreciatedThanks in advance
