shinzon
- 349
- 76
- Sep 11, 2006
St. Petersburg,
Florida
Firstly, I would have posted this in a more appropriate forum, but it seems I can't post elsewhere even though I have been a member of dsmtuners for nearly a year.
I was reading the vfaq page describing how the boost control solenoid functions and I noticed that the ECU was able to close the solenoid if it is detecting excessive knock, thus lowering boost to 7-8 psi and protecting the engine.
Now it seems the usual way to raise the boost level is to completely eliminate the BCS and in its place put a manually controlled bleeder valve. This seems dangerous as you are removing a critical engine protection device. Now I guess it could be argued that you should tune the car so that knocking is minimized, but it would be nice to have a failsafe in case you get a bad tank of gas or something and not realize until you're doing a WOT run. Besides, better to be safe than sorry, right?
It seems to me the best solution would be to modify the stock BSC so that it does not bleed off a set amount of pressure but completely lets it pass through and place it inline before the manual boost controller (so that is flows from Pressure Source > Modified BCS > MBC > Wastegate actuator). This should allow the ECU to still open and close the solenoid normally when it detects knock while allowing the manual boost controller to take care of bleeding off the necessary air to fool the wastegate actuator into opening later when the solenoid is in the normal open position. If its not possible to modify the BCS as necessary you would need to wire in a replacement aftermarket electrically controlled air valve while still fooling the ECU into thinking the BCS is connected so that you avoid a check engine light.
Does anyone have any experience into doing a modification like this? Does someone already sell something which will preform this function? Feel free to poke holes in my idea, its just something I've had rolling around in my head as I thinking about increasing horsepower while still maintaining the overall fault tolerance and reliability that would be in place had the Mitsubishi Engineers designed our cars with the set-ups we're putting on them these days.
