Radiator shroud/heatshield idea?
okm12346
565
22
Dec 3, 2007
Chicago, Illinois
So I've been having this overheating issue and I've tracked it down to the radiator being heat soaked by the turbo components. It usually occurs at idle and although I have a switch that turns on both fans (pusher style) it doesnt do much.
So I've been thinking of adding an aluminum sheet bolted to the radiator shroud mounting points, but should I bend the sheet around the radiator or should I leave the sides open so the air gets out. What happens if I bend the corners and the air doesnt get out as easy.
I cant install stock shrouds or run puller style slim fans. So Give me something here, throw me some ideas.
Blanket the turbo, blanket the manifold. This reduces under hood temps a lot.
Heat shield as much as possible.
Are you running an external oil cooler?
    • dsmmario
    • Detail
    • dsmmario
    • Canadian_CD9A
